so did you ever end up adding a rear sway bar? are you happy with the tj coils?
As it sits now, I don't have a sway bar. It will be in the works eventually but right now my front has so little uptravel that it keeps the rig stable on sidehills (which has its own downfalls and isn't the reason I run little uptravel, a sway bar would be much better).
The TJ coils are ok. I have them tied down top and bottom because I have too much suspension travel to allow them to float freely (they would fall out).
The problem is that the springs are simply too short. They get over-stretched on the droop side and it exceeds the yield strength of the spring and they have lost some ride height.
Most coils have a clamp at the bottom of the spring and use a piece of tube to center the spring at the top which allows the spring to slide freely up and down the tube. When you start talking about more travel and/or lower ride heights you need to either capture the springs top and bottom and eliminate the centering tube or go to a longer coil setup (this is why coilover shocks are so long).
I'm thinking my best solution (before finding money to buy coilovers) is to buy a set of
these 6" TJ coils. Basically, TJ lift springs get most of their extra height from using a taller coil with more wraps, the spring rate is pretty similar (usually a little higher but not much). These coils are probably 5" or so taller than the stock ones (which are 17" tall or so unloaded IIRC), the extra height means that the spring get stretched less and will hopefully survive much better.
Stock TJ coils are either 120 lbs./in. or 160 lbs./in. based on motor and options, so they're super soft (K5 lift spring generally range from 350-700 lbs./in.). They are probably a little too soft (I'm running the 160 lb/in ones), even for the rear of my light-ish buggy (a little over 4000 lbs.). They would be WAY too soft for a full bodied K5.
If you're looking for cheap coil springs for the rear of a K5, I would bet that the front coils from a first gen Bronco would work well.
The thing is that you'll probably run into the same problem as me: you will have too much suspension travel to allow a stock coil to only be captured on one end and you'll have to buy taller lift springs from some OEM application (which are still REALLY cheap compared to coilovers). You can usually find used lift springs fairly cheap.
Long reply to a short question
