How to modify a mech clutch pedal for a slave cylinder
80' 427
NEBRASKA
I looked for quite awhile in the search function and found nothing. Can anyone help me with a link? Starting this soon.
I used a Wilwood master cylinder and attached it to a mech pedal with a small clevis
I may have to do it that way. I was thinking of using the stock one.
I just drilled a hole at the right elevation, put a 1/2" bolt through it with a stover style lock nut on both sides of the pedal, cut the hex bolt head off, drilled a hole through the side for a hitch pin and slid the master cylinder over that.
Never had any trouble with it.
Thanks!
Anyone know how far down the firewall I need to drill?
