[ QUOTE ]
[ QUOTE ]
I'm pretty sure you'd need at least 150ftlbs to get a stud seated
[/ QUOTE ]
I dont believe this is true. Think about this: When you hammer a stud in, lets say you dont get it quite seated. It will seat when you put the wheel on and tighten the lug nuts. Now, do you think the torque wrench will click before you seat the stud all the way? Of course not, because until the stud seats fully, the friction between the knurls and hub will not be enough to cause the stud to stretch. You guys can do it your way, and I will do it mine, just dont tell the original poster that my way will ruin a stud when me and others have proven time after time it does not. /forums/images/graemlins/thumb.gif
[/ QUOTE ]
I'll try it on a spare shaft tomorrow. I only tried it once (humoring a friend) and it took all I could do with a standard length 1/2" ratchet to get the stud all the way in. Maybe the stud was a bit big for the hole, I don't know. I do know that the other 11 I put in with a hammer only took one blow at most two apiece.
Most of the time I have access to a press, which no matter what anyone says, is the CORRECT way to do it.
Since you aren't pounding on the threads and it only takes one or two hits I see no reason not to use a hammer.
