I spent the day tearing apart my steering column to replace my turn signal multi switch. When I moved the smaller plastic cover with the tilt lever running through it a small black plastic piece covered in grease fell out. I'm sure it somehow connects with the metal rod that runs down the drivers side of the column to the high beam switch but I have no clue how to get it installed properly. Any ideas?
