how to re-seat and inflate with WD-40
This is common knowledge in the offroading world. It's an OLD OLD trick ANY real world offroader knows.
Agreed...maybe Rob is havin a bad day? :dunno:
I first saw that working at a truck and trailer place I worked at. That was standard for mounting tires, 'cept they used ether. I recall being pretty impressed at the time. A little while later they built an airtank with a handle and a nozzle about 4-5" wide and almost flat. It had a ball valve on it so 125 psi could be released very quickly. With the nozzle aimed at the bead area one shot of the high pressure air was enough to seat the tire.
Rene
it is a very good tip for people who don't know about it thanks for posting it:D it also works to put odd tires on rims when you don't have the cash to have them mounted at the time. another tip if you cant break the bead on a tire very carefully lay the tire in front of another vehicles tire and carefully drive over the tire but not the rim this will break the bead so you can take the tire off the rim
High lift is good for breaking beads too. A little slow, but it gets the job done.
Rene
Agreed... A little while later they built an airtank with a handle and a nozzle about 4-5" wide and almost flat. It had a ball valve on it so 125 psi could be released very quickly. With the nozzle aimed at the bead area one shot of the high pressure air was enough to seat the tire.Rene
yea i have seen one like that at shops but i have never seen this trick. the running over your tire to break the bead is another good one.... keep these tricks coming. im a newish wheeler so i dont know these things.
I've also heard about using a tight ratchet strap around the circumference of the tire to help re-seat the bead after your tire comes off the rim. Has anyone ever tried this?
sounds cool to me never heard of this on before... why dont they put tricks and tips like this up on the site. stuff like this would be great to know. who do we talk to about stuff like this?
It works. My friends mount big tires like this all the time. The smaller the tire is the harder to do though and you need a pretty beef ratchet strap. Like a 10,000 pounder.
Liability :rolleyes:.
...and just because it can be done doesn't mean it should be done.
Someone try that on one of my trail runs, and the 'no one left behind' rule is out the window.
:surepal:
You could also crush yourself under your axle during an axle swap, Drop a t case on your head, or blow out your back getting a tire on the studs "the wrong way" but all that info is posted up and more. I don't see any liabilty issues... good info here. Should be stickied.
http://coloradok5.com/forums/showthread.php?t=183082:deal::whistle:
I tried this way first, because it sounded safer, but had zero luck so I moved to starting fluid. Which worked flawlessly. We made a long trail of it on the ground so we could stand farther away just in case.:haha:
sorry i never knew it.
OOPS!! I"M SORRY! Thats NOT how I ment it at all. I should have thought about just what I was saying before I typed it. MY BAD BIG TIME!! Again I'm sorry 73redblaze. It's NOT the first time I have stuck my foot in my mouth, probably won't be the last. Not in a bad mood, just a meat head sometimes, wasn't thinkin at all before I spoke.
o thanks man. no i wanst upset by it. we get all diffrent kinds of people on here, some new some veterins. thanks for admiting your mistake though! not many guys on here will.
