what should i use to redrill the perches on my d60, the pass side mainly?
i was wondering if theres a special bit i should use or what. what kind of bit do you have pat?why didn't you just take a grinder to the head of the center pin?patt107 said:most aftermarket center pins are 9/16th and the factory ones are 1/2 inch so you have to buy a 9/16 bit and drill the center pin holes out(or buy1/2inch center pins). i got mine at home depot for $10 and it fits a 1/2 inch drill (its a reduced size on the end)
pat
86Cucvbeater said:why didn't you just take a grinder to the head of the center pin?
tRustyK5 said:Regular HHS bit works just fine. Don't forget you'll need to drill or clearance the spring plates for the center pin nut...
rene
