After having belt squeak and looking at my fan belts I was reminded of how my harmonic balancer has a wobble to it. How difficult is this while the engine is in the Blazer?
on some of them . yes you might have gotten lucky but this is not the kind of info i would be passing out to someone doing this job for the first time . He is correct. Using the bolt to install works most of the time but it can easily strip threads. Use the installer tool.wow your replys blow me awayon some of them . yes you might have gotten lucky but this is not the kind of info i would be passing out to someone doing this job for the first time .
how many people strip the crank or bolt gets stuck in the crank . use a installer tool for best results .
put it in the oven ? have you ever looked at a balancer ? there rubber ringed or fluid filled inside so major heat from a oven will kill it or shorten its life span for sure . and the seal could get damaged in the timing cover also .
and do NOT use a hammer method to install it . you can brake the thrust flange on the crank shaft if you get to crazy or have bad luck .
Anything I need to know when buying one? Is one better than the other? Do they come with a new key?
Dorman is the overwhelming available standard replacement balancer
400 is external. Unless you have a 383 it should be internal.
