Ok so my truck has a drain... 2 weeks and the dual 1000ca batteries under the hood are dead.... ok so truck doesnt go out much...
if i do decide to take it out for a quick run and they dont charge up im screwed...
so im thinking of throwing a solenoid under the hood... run battery cables from the bed to under the hood....
I have 2 x 1300ca dump truck batteries in the bed (size of 4 normal batteries) for my winch.... well it would be nice to just flick a switch and use those batteries to give me a jump......
so I remember a while ago i read somewhere that you could use a ford solenoid...
what year and model should I get? (plus they are cheap and already mount on a fender)
run hot from bed to solenoid and other post of solenoid to one of my batteries...
then wire up a switch.... hot to the switch and switch to solenoid.... is it really that easy???
just curious...
thanks
~Jeff
just curious...
thanks
~Jeff
