Originally titled "Front Springs".
Hello again guys/gals.
As some of you already know, I'm in the middle of reconstructing a Mall Crawler that I traded for, into a (street legal) Wall Crawler.
My question this time involves the front springs. It had these 4-6" lift springs on it when I got it, but they don't seem to have much drop available, and they twist the crap out of the frame on the trails.
I have read over the 52 swap write up seen here:
http://coloradok5.com/52inchspringswap.shtml
It seems simple enough, but I got to wondering, why couldn't I disconnect the existing shackle at the spring head and add an extra 4" rear shackle that I have laying around and effectively be running a dual shackle set up? I would of corse take an old piece of tire tread and fix it to the underside of the frame to keep it from banging.
I know about dual shackle "unloading" but with no more travel than this mod would add I really don't think it would be that much of a problem. Plus the heavy Dana 60 and 37" Hummer Tires should help to keep the CG low. And I'm running a Q-Jet so I can't go vertical enough to unload anyway I don't think. and I can make them lockable for on road use if needed.
My next best option would be to mix these front packs with my old sagging scrap 52's and see what I can come up with, then start moving hangers. I want better travel but don't need so much that my front drive shaft pulls itself in two.
I just thought I would toss this in the sharks pond and see what comes out.
This is not a DD, I do not have to worry about inspections, it only has to be street legal'ish to drive around town and to the trails. I don't plan to drive it on any interstates.
(Pic removed)
(Pic removed)
Got it.
, and I still have a spare 14bff to sell. Once I sell it I'm getting new body mounts, and hopefully a winch soon thereafter.
Heck I'm not even sure what these front springs are, I wasn't the one who put them there. I just know the are way too stiff.
I spend as little as I possibly can. Mostly what I was getting at with that comment was that the more flex you add the more cost you add and it doesn't matter how you do it. More flex=more driveshaft+more shock+more brake line length+steering modification etc.
or
