rocknerd
Registered Member
some play in my driver side tire. with tire in the air and hands at 12 and 6, there is a pretty good amount of play in the tire. how do i tell if its a bad hub or worn kingpin? or both?
also, how effective is the "washer fix" just as a band-aid until I can fully rebuild the kingpins? Just a few thick fender washers on top of the spring, correct?
