HUGE Inventory Sale in WA State
4WheelingPlus
Ellensburg, WA
Doing some rearranging and I need more room to make some changes in the shop. I need to move some inventory. :D
Now I want to sell as much of my inventory as possible so I'm offering incredible deals on everything I have in stock. Pretty much lots of Jeep XJ and 1973-1991 Chevy straight axle lift kit stuff.
I've got several leveling kits in stock as well as complete lift kits for Jeep XJ, YJ and JK.
I've also got lots of locking hubs (Dana 60 and 70 30 or 35 spline), steering stabilizers, extended brake lines (stainless steel and rubber), add-a-leaves, shocks, ubolts (even Dana 60), steering arms and misc stuff that I would like to see go bye-bye soon.
Let me know what you need and I'll let you know if I got it or can get it for you.
How about 2 front & 2 rear shocks ( 8000 hydro Rough Country ) for 1980 Chevy K20 with 6 inch lift. Please quote me a shipped to 01922 price. Thanks !!!
i see a lot of leaf springs... any rear 2-3" lift springs for a 87 K5?
got any poly leaf spring bushings? 82435
I have fronts and rears in stock. I need to know if you need front or rear or both.
I also need to know who makes the leafs you are using or if they are stock. Spring mfg's use different sized bushings.
What do you all have for 73-87 Lift Options?
Might be interested in some front springs, drop steering arm, brake lines etc, depending on how good my next paycheck is.
I could use some extended brake lines - front and rear - 81 Blazer, 10 & 12 bolts
can you quote me both stainless and rubber? for a 4" lift, to 93551
thanks
PM sent
I have all that PLUS more.
I have front and rear springs 2", 4" and 6", add-a-leafs, rear lift blocks 1.5"-4", rubber brake lines, stainless steel brake lines, drop drag link 2" and 4", raised steering arms for the 1/2 and 3/4 ton axles, lifted steering blocks for the Dana 60, ubolts in most lengths for front and rear (even D60 front), shocks for most lift sizes up to 8" but I can get longer ones if needed, ORD shackle flip, sway bar bushings, poly spring bushings, sway bar drop brackets, transfer case drop brackets, steering box frame brace (weld in) + ORD bolt in brace... I might be forgetting something.
Long story short: We got lots of stuff and what we don't already have in stock we should be able to get for you.
