huge white smoke cloud
greywolf
ST.PAUL TX USA
i got a 90 burb guy said it has an engine knock so we started it and nothing:confused:left it running for for about 20min and thick white smoke everywhere(from exhaust).
1)has sat for aleast 1 year
2) no water in oil
3)wont start without help(starting fluid)i think its old gas on this 1
4)idles kinda of rough
i have all the tune up stuff and new fuelpump/screen and filter and a topend gasket kit
tell me what you think the problem is..........
T I A
George
Pressurize the cooling system with a radiator tester. Pressure should hold if not bad head, gasket, Bad gas will just make it run like ****.
It's sat for long enough that I wouldn't blame the head gasket right away.
Get some new gas in it (maybe pull the old stuff out and mix it with gas in some other vehicle), run it for a while and see what happens.
i'm gonna drop the tank and clean it first,i got some b12 spray for the lines.i'll do the pressure check second like i said i have whole top end gasket set.i even got new front end parts tierods,draglink,balljoints and brakes because my wife is gonna drive it for a little while(she wants a tahoe)
thanks for the help guys
pics are in the suburban forum
