hvy duty LMC headlight wiring harness?
digity
Brentwood Ca
I'm upgrading my headlights with LMC stuff. Anyone running this harness? :laugh:
The one item I dont have a regret of buying from LMC (There are more I dont regret but....Another day)
It's not so much "heavy duty" but more like a whole harness which takes the drain from your OEM circuit and instead taps a new circuit straight from the battery (with relays). Heavy duty......Maybe by one or two wire gauge.
But, yes - Great buy and easy installation. Be sure your grounds are solid or your lights will be dim.
Troy B
Ft Hood, TX
You can make the same thing for less money if you were inclined. I didn't feel like building one from scratch at the time.
I'm running LMC's harness with upgraded headlights from another place. Difference of night and day with the combination of both.
The only wiring is to hook to a battery source. Everything else just plugs in. Mount the two relays and you're done.
I am running one as well (with the LMC lights). While you could make one yourself, this is conveniant and easy to install. The $24 is easily worth the hour or so it would take to DIY.
