hyd assist install question
josh86k10
Knoxville, TN
When deciding on where to mount the tabs, what does everyone do to be sure you are placing them correctly? Do you turn all the way to one side and space the mounts for a collapsed cylinder? Or center the steering and pull the cylinder out 1/2 way (4") and use that to place the mounts?
Also, could those of you with hyd assist and crossover with the tie rod in the stock location post some pics on how you mounted the ram. I'm debating between the DIY kit for the diff cover bolts or just welding tabs to the axle tube past the center section (it looks like it will just barely fit this way with one end at the very end of the tierod). Thanks.
Josh
Turn your wheels as far to the drivers side till it hits the stops,(if your ram pushes towards the drivers side) or you want it to max at....Then fully extend the ram. attach mounts to whatever, i like to make sure its alil higher above the tie rod so it isnt prone to getting hit as much.
Heres mine-
