Hyd ram mounting **Check my welds**
MTBLAZER89
3/4 ton status
Kalispell, MT
What is the best way to mount a ram with these type of ends? I am assuming some tabs that fit the opening? It's aprox 1 1/8" gap. Seems like that might be noisy..
i just used some 1" tabs. had to clearance them and trim them down to get it to fit, but it works good. here's a crappy picture that shows where mine fit, can get more if ya need it. i also threaded the clevis end on as far as it would go, cause of the tight fit. i didn't have time to get a diff cover with a tab.
Yeah more pics would be great! Does it make noise while driving?
Where did you get your lines and fittings? I think mine are 3/8 NPT on the ram.
If you don't use some kind of spherical bushing, I think it would be best to mount it like this to avoid binding issues and excessive wear:
(Edit: And with drag-link i obviously mean tie-rod ;) )
The same goes for the tab on the axle tube
(And use some washers to fill out the gap)
Because of the caster-angle, the tie-rod goes both back and down, when steering
I don't think this is a big issue, but why not minimize potential problems:dunno:
I would prefer a greasable bushing though...
Yup, I meant tie-rod :blush:
I've edited it now, but I'm to lazy to change the drawing :p:
Can we get time-lapse video of the process. :D you'd spend more on cut off wheels and replacement batteries than it would've cost you to just buy a kit from Kert! :haha: :wink1:
Whew my arm is tired :haha::haha::haha::haha:
Actually cut pretty good. I'd never cut anything that thick with my torch before but I got the hang of it after a practice slice off the end :wink1:
Still gotta do a little more finishing with the grinder to get the angles matched and all the corners smoothed. Any advantage to making the top rounded instead of corners like I have?
Next comes the joy of drilling a 1" hole :crazy:
DD? No leakage? I'll by doing hydro-assist but I'm not 100% sure on using a diff cover mount - would you use the same method if you were to do it again? Just looking for positive reinforcement.;)
I wouldn't hesitate to use one of those mounts for strength. the force is distributed over quite a few bolts. The only reason i wouldn't be interested in it is the hassle of removing it to change gear oil. But, if you built a cover with a drain bung it wouldn't be so bad. You might consider looking at the option that makes the entire diff cover into a mounting point. I think RuffStuff makes one like that.
______
Nice! :D The torch cuts really do look nice. I've never cut anything that thick with a torch and the cuts sure weren't that pretty! Looks good. :waytogo:
I drilled through 1 1/8" of steel with a 1" hole saw for each of my clevis mounts on the rear bumper. I killed one hole saw, but the second one completed the job just fine. It was in a drill press and it was quite a PITA. I hope you're not intending to do that with a hand held!
Thanks! These cuts came out better looking than the ones I did the other night on some 3/16 :confused: Whatever its better than cut off wheels :p:
No I'll be using a drill press. Good idea on the hole saw!
do you have a 1" bit? If you have one, I think that would be better than a hole saw. I noticed that part of the problem with drilling deep holes with a hole saw is that it has a hard time expelling the chips/shavings. So, it would build up and then you'd have a hard time cutting. It would be hard to remove the chips too - I suppose you could blast it with compressed air or something. However, if you have a drill bit - it should remove the chips for you. :)
Its not a daily driver but I've reefed on it enough to bend the tierod out and destroy it a few times before I built a bombproof one. I'm hitting it with 44" tires and I'm not nice to it.
Absolutely no leaks at all and I would do it again that way and wouldnt think twice about it.
Ok so I got the one tab built. I am not sure if I should leave the top angled, or round it off like the pre-fabed ones?
My next concern is welding this thing on. I have a Lincoln 175 currently still using flux core. Tips?
