I just installed hyd. assist on my crew cab and have a small issue. I used a 8" PSC ram, but I have almost 9" of turn if that makes sense. I turned all of the way to the left and extended the ram to full extent and tacked the brackets in place. Then when I turn back to the right the ram bottoms out before I hit the stops on the knuckle. If I take the bolt out of the ram on the tie rod it will keep going almost an inch before it hits the stops. There is about 7/16" of threads showing on both stop bolts on the knuckles. This is on a D60.
) from it.
