Hydraulic clutch assembly
I might have all of that, I'm doing a Cummins/ nv4500 swap and I need to find out for sure if I can re-use any of the factory hydro stuff. If I can't I'll let you know and we can figure out a number, it's all out of a 86 K5 and most of the system appears to have been replaced.
I have all of that plus the bellhousing. It worked when pulled out of an '85 k30. The hydraulic parts have been in the garage since pulled. $40 plus ride.
Dave
will your hydro set up work on a 91 k5 with 454 swap and sm465 trans? if so, i'm interested
thanks
grif
The set up that I have was pulled from an '85 K30 that was originally a 350 truck but had a 454 in it, with a SM465, so it should be same for '91 K5. I think I should wait just a few for BoondocK5 since he started thread. Maybe a couple more days???
Maybe send me a PM Grif.
Dave
