hydraulic clutch gasket
When bleeding, be sure to have the slave off and the bleeder pointed up.
ok so it snowed so i didnt get far... i need to bleed this thing out..
so i bought one of these from HF.. will see if it works or if it is junk..
http://www.harborfreight.com/brake-fluid-bleeder-92924.html#.UyniMahdXn8
i have one of the manual ones but feel that i am lazy... why not use an Air Compressor?!?!?!
this thing worked wonders... well kinda... only after...
so i was trying to use this tool and it wasnt working... i then tried doing the normal bleeding like brakes... no pumping..
still didnt get a clutch.
Ran out and bought a new hydro clutch master cylinder... and replaced that.
Once I replaced that liquid was gravity bleeding out the other end of the hose as I had it disonnected.
So I connected it all up, used this tool and it pulled brake fluid through great and i watched it go from bubbly brake fluid to solid.
Like an idiot I drove out the driveway now that I had a clutch.. then realized I had no brakes!!!!!!!!! WHOOPS... pulled back in and blead them.... low on fluid on back set (front brakes)... so with brakes I went and got gas.
Drove around here and there...
guessing I still have air in the line because I slowly lost the clutch some... i can get it into first but not second... hope the slave cylinder isnt bad...
so tomorrow my 2013 gets its oil changed... then going to try and get this clutch going then go to inspection... will see...
