Hydraulic Clutch Hoses
nvrenuf
Holy crap, it's running!
Mobile, Al.
Is there any other source than GM for the master cylinder to slave hose? Seems like I've read no but just wanted to ask.
What type of hose is everyone using between the resevoir and master cylinder? I checked the GM hose and it's $50+!! :eek1:
I know you won't like the answer, but pay the $50. At least you can reasonably expect the GM piece to last just about forever, and FIT.
find a hydro shop to make the hose just have to know what ends you need.
I paid the $50 at the dealership.
he needs the resivor to master not the master to slave.
i got some high pressure fuel line with the blue liner in the middle. it has had brake fluid on it for over a year no problems.
3-4 bucks a foot but most good parts stores will have some kind of high pressure efi flex line in bulk. just make sure it has a blue or clear liner in side . that stuff hold up better than std rubber hose.
I run a banjo fitting with with an AN nipple at the slave,a flare to AN fitting at the master,and an off the shelf steel braided brake line with AN fittings on both ends.
I got it at a local hot rod shop but Summit has it all too.
