Hydrazine
B
Bent77
Guest
If you’ve read much about racing, you have heard this. If not:
The Story of the Leathal Fuel Called Hydrazine
by Tony DeFeo
This was a common scene for engines that ran on hydrazine
It’s the liquid so potent, so deadly, so illegal that those in Drag Racing who have unleashed its wrath dare not speak its name in public. In the pits, even to this day, it’s known simply as H. Hydrazine has been around, and used as an “exciter” for nitromethane for as long as we’ve had Drag Racing. Actually, its use as a racing fuel predates even the Dry Lakes. Hydrazine is rumored to have been used by the Nazi’s as an additive in the Mercedes Formula 1 cars of the pre war era.
Here’s the basics of how it works. Nitromethane is a mono-propellant that carries its own oxygen supply. Hydrazine is an oxygen scavenging agent. When you combine the two…even with just a tiny percent of H in the mixture, you get an unstable fuel that is at war with itself. Insanely dangerous, yes…but internal combustion nirvana of the highest order is a guaranteed result.
Lakes era racers who experimented with H found that a stock 90 horsepower flathead would pump out better than 300 horsepower simply by sucking this stuff through its Stromberg. These same racers also discovered Hydrazine’s major drawback for practical use. After running it through an engine, the carbs would start to cake up with a substance that resembled soap flakes. This nasty little by product was a shock sensitive explosive called the Methazodic Salt of Hydrazinium Acid, and was the result of allowing vapors from the Nitro/Hydrazine mixture to condense in a closed environment. Right, never mind this stuff will throw your crank on the ground after just a couple of runs, but if you happen to tap the carb with a wrench, it’ll blow your face off. Let’s go racing!
Hydrazine had its big moment in the sun back in 1960, during the height of the NHRA fuel ban. Barnstorming Top Fuel racers were all clustered together in the 180 mph range, when out of the blue, at a small track in Alton Illinois, the Greek shoved a big gulp of H down the throat of his Chrysler and ripped off an unheard of 204 MPH pass, boiling the hides and wheelstanding right through the lights.
The Ramchargers were known for experimenting with all sorts of fuel, including hydrazine
Several years later, during the dawn of the Funny Car era, many injected cars were known to brew up a batch in order to keep up with blown Fuelers. Shotgun like exhaust notes, bright green header flames and crewmen frantically draining fuel tanks in the shutdown area were telltale signs that H was in the house.
Even though Hydrazine has been on perma-ban by every sanctioning body that has ever existed, its use in times of extremely tight competition, or when a barrier is on the verge of being broken has continued right up to the modern era. We can remember one nighttime qualifying session back when the 300 mph barrier was about to fall in Funny Car, when one of the cars in contention for the honor made a lap with those freakish header flames dancing up over its roof. It was so obvious that a sudden buzz amongst educated onlookers erupted. Even the announcer that night took note of the unusual site. Officially, it was played off as burning copper from a failed head gasket…but then, the very next pair of cars, there it was again. Eight bright green candles lighting up the nighttime sky, and yet another barrier crushed. Was it really hydrazine at work? Only the guys mixing the fuel that night know for sure.
Yeah, it’s dangerous stuff. Handled improperly hydrazine will kill you in ways you can’t even spell, but its a glorious part of the history and heritage of the thing we call Fuel racing.
Nasty Stuff!
Go down the rabbit hole and read some old guy stories on the HAMB. Lots of interesting little tidbits from guys using it back in the day.
hamb
I did a report on Hydrazine for a physics class in high school. Dad had a dropper bottle of it in a metal cabinet for years. It might have been how I got my 30% nitro, 50% methonal and 10% castor oil mixed RC boat to go over 100 mph when the record was in the mid 90's.:whistle:
So 30,50,10 add up to 90%, was the other 10% was hydrazine? Yikes dude!
Ran some things called glow plugs and some kind of alcohol mixed fuel that was recommended by a friend, car ran fast but kaboom at the finish line, that engine was scrap after that. Bummer part was it was a 389 tri power, car was a 66 le mans 4 door. Dad didn't quite believe me that I said it blew on the shift to second with the powerglide. But he said, I bet it was fun for about 10 seconds. Yep he was right again!
Typo. 60% on the ethonal. One drop of Hydrazine per 8 oz. of mixed fuel. Right before the run.
We also played with liquid mercury on the kitchen table as kids. I had great parents.
So the saying a little dab will do you works in that case huh?
I remember cleaning out my grandparent's garage when I was a kid. Grandpa was a retired engineer and master tinkerer. Among all the baby food jars with the lids screwed to the bottom of a shelf was one that had this really neat silver liquid sitting inside it. The rest had screws, nuts and other hardware but the liquid caught my eye. Dad came around the corner when I found it and stopped me right away. Said he played with it as a kid, but found out later it was pretty nasty stuff. Half a jar of liquid mercury in the garage. I don't have the foggiest clue what old Grandpa had it for.
Looks like the some of the links from Zoo's article are gone with the wind
Here's one about the Surfer's Tom Jobe. Helluva interesting time
I"ve been able to talk to some of the old guys, but don't remember them saying anything about the Surfer's running hydrazine
But their fuel system dynamics are in the article. Forever changed fuel racing
I remember reading the article in Hot Rod about the Surfers years ago. A fascinating group of dudes. The fact that they were probably smarter than the rest, they kept it cool and screwed with everybody just to do it. But the car flat ran and it pissed them all off. As smart as Jobe was I wouldn't put it past him to know exactly how much hydrazine to throw in the tank to get the edge.
We played with mercury when we were kids.
We didn't eat it though
We still have a jar of mercury somewhere around the shop. You use it in coated neon glass to make it light up brighter. My wife worked with an old neon bender that didn't use safe practices when working with the mercury and he ended up losing a chunk of his jaw where mercury had settled into the bone. Neon benders have a little tube they hold in their mouths to blow into the neon tube with. So the chunk of jaw that was removed was where he had held the little tube in his mouth. Most benders these days won't even do repairs on coated glass in order to avoid messing with mercury.
Too many restrictions and craziness around mercury to make it worth it probably.
We had a mail carrier drop a package a few years back and some mercury came out of the corner. Like a few drops.
Emergency crews shut down a 4 block area, and evacuated most of the people for over a day.
Package had a test tube half full being sent somewhere. City lost their mind like it was nuclear waste.
And hydrazine sounds fun lol.
I'd probably be one of the ones to blow my face off.... But as stated, it'd be a fun 10 seconds lol
I did not realize this until just now but every F 16 fighter jet has hydrazine in its EPU (Emergency Power Unit).
I wonder if some General Dynamics engineers back in the early 70’s were drag racers?
I like going fast but I'll pass on that. Can't go fast if you're dead!
Hydrazine is used on spacecraft (satellites, orbital craft, etc). Not so much the main boosters. It is however one of the biggest thorns in my side dealing with spacecraft tooling. Any area that can see that stuff, the 20 foot radius around it, the waterfall area below it, and everything 18" off the ground in the building, requires some of the most expensive and impossible to build electrical systems. Motors cannot have a surface temperature warmer than human skin, electrical enclosures require positive pressure, all connections require special designs to prevent any arcing down to no static shocks... that fuel will turn a $700K project into a $7M project real quick.
