Hydro assist questions!
Run it on the return side with clamps. Works better if it can get some clean air. What are you running for e reservoir.
Ok so ill get some hose to go from the pump through the heatsink and back to the steering box.
I was thinking i can mount it in the grill but ill have to see when i get it.
As for a reservoir ill just be doing the radiator hose extension. Just need to figure out what oil fill cap to get that will sit in the radiator hose snug.
Or better, find an old reservoir at a junk yard, and cut a bigger piece off, so you have more to clamp too.
Martin
