Well, I finally cleared my plate and got started on the hydro bender. I've ripped most of the design from the the other two that are on the web. Once I'm done I complete the write up and links to the other benders.
I started by setting up the lower arm of the bender on the ship channel. One thing that wasn't clear from the other writeup was how far in the arm should be.
I figured out from trial and error that it should be in far enough to allow room for the outter support to be welded in, as this next photo shows.
I marked and drilled holes for the arms on my drill press. They are 3/4 inch and are 2 inches apart.
I mounted the bender arms up and check to make sure the bender would operate at this location. I was pretty sure I was good, since I already drilled the holes.
And a look from the other end.
I'm at a stopping point since I need to either buy or make a spacer for the working end of the ram. The ram has an ID of 1 inch and the hole on the arm is only 1/2 inch. I know on the other hydro bender they builder just drilled out the arm. When I look at it is just seems like that is removing to much material from the arm.
But that's it for now. Once I get this figured out (and the Daytona 500 is over, I'll get back at it).
