gerber boy
hey, i'm hoping you guys can save me some fu*( around time. i've tried searching but can't find my answer.
I'm tearing down a 92 1ton with hydroboost, i want to install it on my 83 K5. I'm wanting to know if this is a fairly direct swap? can i just remove the vacuum booster and master from the K5 and install the master and hydro from the 92, and remove the abs controller?
has anyone done this before?
oh and the trucks a 6.5 and it's going in the K5 so i'm not worried about the pump
thanks.
thanks.
