Is there a blazer or truck that I can get a hydroboost system from that would fit my 88 blazer?
Any information will be greatly appreciated.
thank you,
Ed
thank you,
Ed
The K5 system I used was complete w pedal assy
I did use a 78 K30 m/c that bolted onto the hydro unit fine but I had to make a pushrod spacer to get the stroke right. The K5 pushrod was about 1/2" short of the piston
https://ck5.com/forums/threads/77k5-the-ironmaiden-funnernhell-bundyhill.261694/page-238
Go to July 16/2015 for more info on my setup
It works awesome!
Do I need the brake petal from the donor hydroboost system?
What's the difference between the hydroboost brake petal, and the petal that's in my blazer? I have and automatic transmission.
I'm just trying to learn about the component needed to better understand what I need and why.
thank you,
Ed
I used a square body hydroboost unit and a GMT400 Master cylinder. I do not like the rock hard brake pedal that a cast iron master cylinder provides.
Braking power has been excellent.
