hydrobooster leak help
tp85
Maryland
Hi guys,
It seems my hydrobooster is leaking power steering fluid. I tried to find the search function on the board to no avail.
Could someone please tell me what my options are? Are there o-rings/seals etc. that can leak, or does this normally require replacing the hydrobooster unit? Do you guys have the procedure documented somewhere? Do I have to break open the brake system...needing to bleed the ABS unit and brake lines?
1994 K2500 Suburban
Thanks for your help.
Tom
tp85 said:
Hi guys,
1994 K2500 Suburban
Tom
The hydroboost unit is mechanically coupled to the master cylinder, not hydraulically, so as long as the master is not leaking, you don't need to open the brake system or bleed it. You'd just unbolt the master from the hydroboost, just like you'd undo a master from a vacuum unit. Basically, the hydroboost has a rod that pushes the piston in the master, and no fluid should get in there (I say should, as mine had brake fluid in it when I got it ... doh. New master in that case.)
I see rebuild kits on Ebay for hydroboosts from the the military... or the local parts place will sell you one for $100-150 exchange, I do believe.
HTH.
-- A
i thought i had the same prob but after replacing the booster in figured out it was the crappy/beat hoses, fluid under pressure really travels.... :blush: try replacing the hoses first, it solved my problem but 150$$ later than it needed to...
