So, right before I moved my K5 the last time, I decided to top off the fluids, as I was told the transfer case and axle were low. If you've read anything else I went through with this truck, you'll know that I received a lot of bad advice in the past, hence my decision to become a member here...
Anyway, I topped off the transfer case with 85W gear oil. Stupid assumption on my part.
So, don't the 700R4 and NP208 share the same fluid? I know the case uses ATF as well (now I do...). The truck was driven about <200 miles and then shut off where it now sits.
Will flushing the tranny really good clear out all of the 85W? Do you think I did any damage?
