I could see the road pass beneath me!!!
blbikerood
Registered Member
Missouri
No really I could. Near the rear bolt on the driverside seat a hole had formed. Not a rust hole, but a hole from weight and years of abuse. So i put the truck in a shop at the school I work at and we yanked out the seat.
We then put a jack under the rig, and jacked the hung down floorpan back up where it should be and welded a good solid bead on it.
I then ground it down and put the seat back in. Man what a difference that made! I was weeblin and wobblin and not fallin down, but now I sit real solid! It isn't a perfect fix. Ideal would have been to cut out the bad section and replace with good sheetmetal, but this should last a couple of years at least. I included some pics.
http://s297.photobucket.com/albums/mm213/blbikerood/?action=view&current=IMG00211.jpg&newest=1
http://s297.photobucket.com/albums/mm213/blbikerood/?action=view&current=IMG00213-1.jpg&newest=1
