mudslinger99
Well you will always get a wide variety of opinions when it comes to axles.. Some say they have run 10 and 12 bolt stuff for years with no problem..Others say they broke a 12 bolt in one ride to the grocery store.. But there is a big difference in what terrain people are running in and how heavy their foot is..
Around here 1/2 ton running gear is more common and believe it or not most of the time preffered for a play truck.. I think it is mostly due to ground clearance, availibility of parts and the fact 1/2 ton stuff is cheaper to replace because you can find parts every where...The fellows I have went wheeling with around here run up to 44inch tires on some pretty heavy trucks that get abused pretty hard with minimal breakage for years... But keep in mind we mostly have mud to play in.. I'm sure bigger axles would be more popular if we had more rocky terrain..
I think the major reason that you see so many people going 1 ton is the terrain they run and because it is cheaper in the long... Like has been mentioned by the time you build up the 10 and 12 bolt to handle the terrain in most cases you can go 1 ton for less and have a much stronger set up... So think about what everbody has said and decide what is best for you..
That is a good looking truck you got there..Also nice lay out on your site.. Good luck to you on what ever you decide..
....it will cost you some good money to buy a re-buildable one, and then to go through it and replace seals and bearings will cost you some more. Odds are you'll want to do crossover steering at about that same time, and you'll probably want a selectable locker if it's a streetable K5. It's not hard to get $3500 into a front axle (with steering) if you go that route.... I don't mean to be the "reality broker" but sometimes it's better to know in advance what you're in for.
) The older 8 lug SF14B are about 1/2 that and the FF14B are a little less. I sold a complete 3/4 Dodge w/ a D44 front a FF D60 rear a few years ago for a couple hundred bucks. That should give you some ideas on price.
