Alright guys the other day i traded my car trailer that I had 500 bucks in for an 85 blazer, 305 4 speed, drove it home, ran great, it came with a bunch of tune up parts so last night i started with plugs and wires, super simple right. Well initially everything was right but then I decided to reroute the wires and somehow I crossed a few of them. But I didn't find that out until today when I fired the truck up to drive it, it cranked right up, I started to go around the block, I get about half a mile and realize something isn't right, truck is shaking and running bad, I figure it is just cold natured because I thought I had the wires right, then I go the rest of the way around the block, and head home because now i suspect crossed up wires. Go home and sure enough, several are crossed, keep in mind the truck was running, idling and everything up until I pulled it down the driveway to fix the wires, then i shut it off and fixed the wires. I go to crank it up and it cranks over slowly and then it will intermittently speed up to normal cranking speed then it will stop ad then it will go slowly again. Anyway, it wouldn't start. I squirt some brake clean down the carb and crank for a little and finally it catches, i hold it about 2000 rpm and rev it some, sounds ok, then I let off the gas and it dies abruptly, not like sputtering out, i took my foot off the pedal and its like boom stop. Anyway I quit there, figured i will check with y'all and try again tomorrow. Im almost suspecting a bent pushrod, what do y'all think?
