So being a used truck, there are things to fix. Per my list in the first post.
Now my girlfriend had only seen pictures of the truck. So on her way home from work on Friday, she stopped by to check it out. I was planning to move the truck inside, was stupid cold yesterday and today.
I had to move the truck around the building, we both get in. Go to start it and clunk. 2nd try, clunk. Ok this sucks.
I'm not climbing under the truck in 15°f weather with 40mph winds. Forklift it is
, pushed inside with ease.
No start situation. Check the basics and found the trigger wire to the solenoid had come loose from a previous repaired connection.
Quick and easy fix. Tested and works. Batteries were very weak. Quick load test showed they were pretty much dead. 10 volts each under load. $390 for 2 Batteries at napa!
While fixing the wire I found the starter support brace is missing. But oh it gets better! The bolt that holds the brace to the block was broken off.
No choice but to fix it. Ground it flat. Drill it out and installed a heli-coil made for a 5/16 bolt.
Underbody light and right angle drill for the win. That and cutting the drill bits down to be short enough to fit in the available space.
This was fun to tap. But I have tap socket adapters, which it made it so much easier.
And yes, I used the drill to drive the heli-coil in and break off the tab.
I made a short drive tool out of a cut drill bit. Worked very well.
And fixed.
Now to buy or make a new bracket.
I had planned to check the brakes, since it pulls bad. We'll, it's getting new pads and rotors.
Not what I planned, but was a productive day.
