I like having torches too--without them you might as well forget fixing anything around here more than 5 years old..I hate having to FILL the tanks though,its always a hassle and expensive,when your not a steady customer with an "account" at a welding supply house..I consider torches more important than any other tools,the next best things are sawsalls and cut off wheels in a grinder..
I hate living around here,everything I own is a rusted peice of scrap iron in 5 years,and 99% of every "problem" I have with my vehicles is RUST related,not due to wear or normal fatigue..I'm willing to bet I'd be 20,000 bucks richer if things didn't rot away so fast here..I'd still own every car & truck I had since I got my license,some of them would be worth 10-20K now..not to mention the thousands in parts I had to replace and the toll the labor took on ME..
The "engineers" who design some of thios stuff should be ball kicked repeatedly in the groin for making things impossible to repair and using recycled crap steel to make it too..
Yesterday I tried and FAILED to change a stupid gas filter on my Ford Contour..
I'm a guy who is still stuck in the 80's and beyond,I can fix anything on my old trucks--put me under the hood of a 1990's or newer vehicle and I'm a clueless idiot..
It makes me feel like a washed up,useless obsolete cripple,when I used to be able to yank a motor out of a 70's GM truck and have it installed and driveable by 5 pm the same day..now I cant even get a effin fuel filter held on with cheesy PLASTIC clips off,for fear of busting the cheap PLASIC fuel line connectors that are brittle..
I battled with it for 15 minutes,then gave up,put the new clips on it from the new filter back on the old one--and now I'll have to bring the car to a friend's repair shop, and waste more money I dont have ,because I am unable to do it on the ground ,and cant see for S*** with my aging eyes..the hose clamp that holds the filter on cant be loosened thanks to RUST eating the head of the screw on the clamp off too..
To make matters worse,I walked right into the floor jack's handle when I was blinded by the sun,and smashed my shins so badly I can barely stand up now!..
The car needs an oil change and rear struts installed too,I have a pair with springs I got from a salvage yard that were replaced recently,but after getting discouraged with the gas filter,I said screw this--my friend can do ALL of the repairs,I dont have a small oil filter wrench so I didn't bother even doing that myself..
Needless to say I'm thouroghly disgusted with myself,I've gone from a pretty good mechanic to a useless F*** in a matter of 10 years..cant even change my own oil or gas filter any more..
I get so pissed off at newer vehicles,with retarted designs like clip on fuel filters and nylon lines--what was so bad about rubber hose and worm gear clamps??..I trust them 100 times more than a hunk of plastic,especially with high pressure EFI !..
--snap-loc tranny and coolant lines,plastic water outlets,etc..what a pile of feces newer vehicles are..they cant be fixed by the average joe--.
I would be royally boned if my car needed a starter,altenator,or radiator hose out on the road if I were on a trip--you have to dissasemble half the car,the exhaust system,etc,just to put any of those on it..and it'll cost more than another GOOD OLD GM truck I CAN fix would cost,just to tow it home or have someone fix it...makes me want to peuke every time I go anywhere in my car ,knowing I'll be screwed if anything goes wrong with it..I dont feel so helpless when I'm in my truck,and could fix 90% of anything that might fail on it..I'm seriously considering selling it...
