Ok so I have been a member on here for a little but I only ever read and look for info that I need, but I'm at a loss right now. I have a 1986 K5 that I did an axle swap into and in the midst of a motor and trans swap plus a 4 speed atlas install. All these parts have come off of a 1987 k10 that had 8" of lift with a 383 motor and turbo 400 and a custom np208 to np208 doubler with 44" boggers and the axles as well which are 35 spline chrome moly shafts and a 14 bolt which both have 456 gears and welded. now this this info i'm trying to finish things up with the motor swap and I'm stuck with my radiator...... Its a stock looking 4 core radiator but I can't seem to find the correct rubber mounts or the correct radiator brackets that hold it in place. And the reason for that is while doing all this I took the front clip off and changed it to the cross over years for a blazer or burb of 89-91 and not I can't find online or in any local junk yards the proper rubber mounts or brackets for that style radiator support with a 4 core radiator. I guessing that a diesel truck of those years brackest and rubber mounts would work but I can't find any. I tried looking on line and anything I find is only for a 350 or smaller motor and I know that wont work. If any body could help me or knows any where to look i would really appciate it
