So since I blew the front driverside ujoint I started taking the hub apart to replace the ujoint and find out that not only are my wheel bearings bad, but my ball joints are shot as well as the spindle bearing was NON-exhistant and the seal was toast. So basically every wearable part in the driverside knuckle has to be replaced. The passengerside is good since i replaced the wheel bearings 2 months ago.
So right now I have hit 2 road blocks. I cannot remove the knuckle from axel. And I can't remove the bearing out of the spindle. Here's some pics to show you where i'm at:
Knuckle is torn down, all nuts removed and the snap ring on the lower ball joint is out. I have been wailing on the upper ball joint with a 10 lb sledge and haven't gotten any where. Plus boat loads of PB Blaster.
So what's the story with the adjusting sleave? Does it have to come out to remove the ball joints? And where do i get the special wrench to turn it, NO ONE has it locally?
Lower ball joint
Spindle bearing:
Ujoint:
Also one more question, what is this joint called and what do I need to do to replace it?
Lower ball joint
Spindle bearing:
Ujoint:
