I need to be skooled on recentered h1's..please
Colttan
Registered Member
Bells, Texas
I found a dam good deal on full set of brand new tires and ce centered h1 wheels I just need to be skilled on the way there beadlock system works how to take them apart and put back togetther thanks
The most important thing to know is to never take the wheels apart when they are inflated. As long as you have an insert in the tire (mag run-flat, rubber run-flat, PVC, etc, mounting the tire is simple. Set the wheel on a bucket or something, drop the tire on, set the ring in place and put the nuts on. Without any insert, you get the hassle of setting the bead.
The only thing hard is actually getting inserts in and out of the tires. 8-bolts work the same whether recentered or stock because the WMS is in the back portion of the wheel. 12-bolts change a bit because the WMS is cut out of the front part of the wheel and welded into the back. After recentering the 8 and 12 bolts work the same.
Getting the PVC inserts isn't too bad as long as you lube the tire everywhere the insert hits. I have 4 of them to take out this weekend. Out is worse than in
Thnks for all the reply's guys. Is there a limit on how far I can air down with this setup
Waaaaaaay worse... :haha:
You could wheel at 0lbs, you'd just risk ripping up yer tires....
The bead'll stay. :haha:
