One of these days, if someone asks, or if I get bored, I may write up a small piece on Ohms Law and how voltage drop works.
But, I AM NOT going to write up a piece on antenna theory.
It would take volumes, and cause the biggest flame war you ever saw. Even though I could give references and documents proving every thing I said.
Having said that, let me clear up a couple of issues.
The antenna, the part that is hooked to the center conductor of the coax MUST NOT be touching or hooked to ground.
Good way to possibly burn up a final.
But, unless it is a special marine-type antenna designed to be mounted on fiberglass, it MUST be mounted to metal that is grounded to the same ground reference that the transmitter is grounded to.
This piece of metal is what the little connector on the end of the braid is hooked to at the antenna.
Now, since the braid is grounded at the radio end, it will electrically ground the metal that it is hooked to at the mount.
And this will work, after a fashion.
But among other things, it tends to cause an RF current in the braid, and that is normally not a good thing.
The thing is, the antenna you put up and looks so pretty there, is only half the antenna.
The ground plane, the metal under it that it is mounted on, is the other half.
And the amount of it, and its shape, helps determine the radiation pattern.
IN GENERAL, the antenna transmits and receives best in the direction of the most metal.
In other words, if you have a metal top, and you mounted a whip on the left rear of the top, then the signal would be strongest towards the right front.
Mounting it on the left rear bumper, would seem to do the same thing, but having it run right past the metal body and top makes for some strange differences.
You get all kinds of weird reflective wave problems coming back to the radio, and there is sometimes some "backscatter" off the metal roof and body that causes a small lobe of RF energy in the opposite direction.
But, just in general you just lose power as its absorbed by the metal and by warming up the coax slightly.
In one of those cases, I usually recommend a top loaded antenna. Firestick makes them I think.
http://www.firestik.com/CatalogFrame.htm
There are lots of others.
If you go with Firestick, I suggest the Firestick II series.
It has a tunable tip where you adjust your antenna with a screw in the tip of it.
Some of the others have those too.
Usually they are worth it.
The top loaded antenna transmits most of it signal from the top. Look at one, and you will see the larger coil at the top.
Electrically, this is where most of the antenna is, so that is where most of the signal goes out.
If you have one of these mounted on the back bumper, and its tall enough to get that coil above the roof, it will work better.
