Stomis
Professional Amateur
Ive been down this road before. Went from buzzing screwed up wipers to fixing them initially when I first got the truck. I had loads of electrical stuff wrong, ignition switch that was leaving certain circuits constant hot and not power some at all, wires jumped all over the place just to get them to work, replace the pulse board added the ground to them back in the PO cut, and fixed the buzzing and got them working except they wouldn't shut off. That turned out to be the switch no cancelling properly.
So now that the LS is in and Im wrapping up the harness I had to rewire the windshield wipers. What a pain in the ass. The connector cost me $40 at the junkyard, a hasty move on my part thinking I was going to wrap things up that day and it would be worth finishing... Regardless. I start peeling through the wiring I find that the wiper low switch ran through the old ECM plug. So I jump that back and get it through the bulkhead on the firewall.
Now Ive got:
White to ignition fused wiper as the constant power source for the motor, all good there.
Purple 12v from wiper switch for high, works great
Grey 12v from wiper switch for low, works great
Now I have this orange wire left that is suppose to function as the cancel/intermittent and the washers and for the life of me Ive got no ****ing clue how to wire this. The schematic shows:
So Im pretty good with this stuff, not an expert but I can usually work my way through this stuff. Im lost after today. There is no signal wiring as called out coming from my steering column. The wiper switch has 3 wires not 4 as shown in the schematic. The blk/blue that turn to orange and goes to the motor is MIA. And I searched looking for perhaps a wrong color in the diagram and no luck.
Also I dont follow the schematic on these washers. If I splice the orange wire to the pump it will be on all the time as it goes hot out of the motor disconnected with the wipers on.
Anyone have some insight to help me out here? It has a brand new motor, and pulse board in it. The switch is also brand new but Im considering taking the column back apart to see if I crushed a wire maybe...
Now Ive got:
