Hi guys!
I need your advice. I live in Ukraine. It has long dreamed of an American truck and just recently I changed my Range Rover on CUCV M1009 1986 V8 6.2l D TH400 NP208.
Now I am engaged in the restructuring of my K5. Replaced with a axles GM from a Russian military truck GAZ-66 axles tires 12R18 (42") gear ratio 6.83. Must change transfer case because now the front axle gearbox is on the left side. I also want to get good speed on the road 65-75 mph. T-case TH 400 is not overdrive in this to look how to solve this problem. Is possible to change the gear ratio of - 6,17; 5,5; 4,56. It may be possible to solve this problem installing the overdrive? And what the normal engine RPM at cruise speed for the engine 6.2L D ? Plan to use my truck for trips to hunting, fishing where many will have to go in the woods, mud, sand and on-road.
My question is:
- What a powerful transfer case you suggest?
- What gear is better put in the axle?
- How to resolve the issue with overdrive?
- What maximum engine RPM 6.2l D while driving on-roads?
Thank you for your assistance and look forward to your responses.
Serjioz
Now I am engaged in the restructuring of my K5. Replaced with a axles GM from a Russian military truck GAZ-66 axles tires 12R18 (42") gear ratio 6.83. Must change transfer case because now the front axle gearbox is on the left side. I also want to get good speed on the road 65-75 mph. T-case TH 400 is not overdrive in this to look how to solve this problem. Is possible to change the gear ratio of - 6,17; 5,5; 4,56. It may be possible to solve this problem installing the overdrive? And what the normal engine RPM at cruise speed for the engine 6.2L D ? Plan to use my truck for trips to hunting, fishing where many will have to go in the woods, mud, sand and on-road.My question is:
Serjioz
When I decided to install the big tires on my K5 is faced with the problem of searching the required donor to replace the axles. Then I decided to use parts from the Soviet army truck GAZ-66 - V8 engine 2 ton 42"x12"R18 (or 51"x20"R21) front and rear axle gear with locking differential of the same slip and automatic regulation of pressure in the tires. I think the change in the ring gear of 5,5 in axle. At 60 MPH -engine RPM is 2640, is normal?
