Bigb55
Decided to go with new carpet instead of bedliner. But wanted some good water resistance on the floors. Front had all rust cut out from previous repairs. Cargo pan still had perfect factory Grecian bronze paint and zero rust.
Scuffed it all up then put down 4 coats of rust bullet. Made a 1/2" to 1" edge on the edges. Then coated it all with a single stage urethane in summit white.
Came out pretty nice! Definitely will keep water off the metal and out of the seams as much as possible. This is a cruiser not an offroader so any big leaks will be dried a day or two after it happens.
