- Joined
- Mar 12, 2004
- Posts
- 2,647
- Reaction score
- 1,043
Does anybody else have this problem or is it isolated to me? This cap and rotor is only 5 mos old and the rust is the same age as well. I can not keep this dist from rusting to save it's life. I have taken it totally apart(3 times to be exact) wire wheeled it, sanded it, and smothered it with dielectric grease but to no avail. Along the same lines why is the cap corrosion so bluey and why has every cap I have changed out had the center electrode burnt to almost not there, as well as the rotor cap where it contacts looks like it's been spot welded. When it's fresh it works like the dickens but is becoming quite spendy & time consuming having to replace and clean this up as often as I have been.
Chris
Chris
i live in the rust belt and my msd stuff didnt look that bad when i use to run it on my mud/snow wheelin truck
