az-k5
10 days. That sucks. We get 30 in AZ.
az-k5 said:10 days. That sucks. We get 30 in AZ.
Down with special interests!
How do I check my engine temp sensor?SierraClassic said:One thing -- Check your engine temp sensor, if its outta whack, and thinks its colder out than it is, it'll up the engine RPMs like you are experiencing, and richen the mixture to "choke" the engine.
Second, VSS -- Its so easy to install on these trucks for TBI, its crazy not to run one. Simply get an 83 - 86 cluster with a green optical sensor on the back of the speedometer head. Sure, you loose your fancy 100 mph tach, but how often do you go faster than 85 mph anyways? It'll be a direct bolt into your 79, no wiring changes less giving the VSS it's power, and ground, then passing the signal directly to the pin on the ECM.
Those TBI trucks use a 2000 ppm signal, which they normally get from the DRAC in the newer trucks, but that VSS on the speedometer, which is used for the cruise control stock, will operate the TBI without a hitch![]()
Just to be clear, ALL wire cutting and splicing will be on your harness. Not mine!B_to_C said:My old truck was a 90 so it had a DRAC. This weekend I will be installing a speedometer from an 88 blazer...with that box on the back to send a signal to the ECM.
I'm sure you'll have to do something to hook the wiring to a different source.
