Citizen Rider
Replace the plugs deffinatly. Dont get platinums, ive always had trouble with them and end up fixing friends that use them. Cheapo ACDelco plain plugs are worth the 8 bucks to replace. Even if its not the problem....
) one unresolved question.
Regardless of whether you use the lockup function, the vehicle speed
sensor (VSS) must be used and is needed by the computer so that it can
command the emissions control devices on the engine. This part is
necessary if you want your vehicle to be street-legal.
dyeager535 said:You can do that, (falsify the P/N setup) but it's not right. That stuff is tied into throttle following, etc...it wasn't tied into the ECM just for the heck of it. I'm sure timing is different as well. There's a reason auto and manual PROM's are different.
They will certainly run like that, no idea if it's enough to cause a failure during emissions or not. It won't help though, that's for sure.
Is there a way to make my PROM think it's for a manual, or get a PROM from a manual truck? -which would probably be damned near impossible, because I think I would need a 1990-91 manual blazer / burb / Crew which may take milleniums to find in the junkyard.
700R4 is not considered to be electrically controlled like the 4l60e. Only the converter is electrically controlled for lock up in the 700r4. Hollander does not show a different ecm for a manual set up. You have a sensor either faulty or not hooked up somewhere on the emmisions side.B_to_C said:Is there a way to make my PROM think it's for a manual, or get a PROM from a manual truck? -which would probably be damned near impossible, because I think I would need a 1990-91 manual blazer / burb / Crew which may take milleniums to find in the junkyard.
dyeager535 said:If your engine is stock, you may get away with just getting a *stock* manual PROM with EGR turned off (and AIR and EVAP to be thorough) which should be pretty cheap. $40 maybe?
