digital camo to be exact. Came out better than I had hoped. Pretty stoked.
I've seen some large sheets of vinyl on ebay that would make it affordable, probably between 400 to 600 like Merrick mentioned. I have seen some 5 x 10 foot sheets for around 38 bucks and if you did it right you can do each side of the truck with about 4 or 5 per side, then one for the hood, and maybe if you cut it right you can finish the tailgate with some of the leftover. I could use a Tailor's tape and figure out the cuts and total quantity exactly but I'm so far away from worrying about the outside of the truck I have not made a priority out of that. Only thing that will be a real pickle is the cowl behind the hood but even that with a little practice can be done easily enough with a razor knife and propane torche. I'm thinking of doing mine in a brushed aluminum finish and then blacking out all the chrome garbage... The nice thing about the square bodies is it's basically a brick. I think the top will be a bit of a challenge but I was just going to make the cab be one piece that runs down and divides at the joint lines.
Here is a link to that material I found. I bought a large piece in black brushed finish to test out on a motorcycle tank but I have been to busy with the truck to even tackle that, lol.
http://www.ebay.com/itm/Brushed-Alu...elease-/272013660582?var=&hash=item3f554711a6
Yea that remains to be seen. I still have a lot of scrap left and cutting out a scratch and replacing is very easy.
Seems like this day would never come. The body was the last thing I thought I would deal with. And here I am. Pretty cool feeling
