So, to mount my rear shock brackets, I'm going to need to drop the fuel tank on my K5. Seems like the time to take on the fuel pump question I've had for a while. I'm running a FiTech, so I need the higher fuel pressure that comes with the later throttle body style pumps. When I bought the truck, it had an external pump mounted inside the frame rail, which is working perfectly. I even have a spare pump for the trail.
Problem is, I've read countless places that the pump is supposed to be mounted lower than the pickup, usually recommended that it's lower than the tank. As you all know, that's pretty hard to do on a K5 with a stock fuel tank, unless the pump is in the tank. So I'm looking for a little advice from those of you who have had an external pump: Where did you mount it, and did it last? It's certainly easier to change out a bad pump on the frame rail than one in the tank, so maybe it's worth it to just leave it where it is. The pump is pretty close to the tank, but it's just above the rear axle, making it a good 10" higher than the bottom of the tank.
What is the best way to set this up? I know changing an in the tank pump on the trail with a half tank of fuel can be a problem...and it usually happens in the rain or when it's 115 degrees in the shade. How important is having the pump be lower than the tank?
