Is there a reason you wouldn't put the valve in the tank other than it being a pain to get in there? I'm thinking is all fuel safe materials, it would seem submerging it wouldn't hurt it and would be the only way to ensure I don't get air in the fuel line.
Ideal location is inside the tank.......So you're asking what is the 2nd best location?
Point taken....However, when you taken into account the difficulty of replacing the pump, I'm not sure the external pump is clearly second. I think everyone agrees the tank is the best location to make the pump work the least and last the longest. I've only had one pump go out on me away from home, and it was pretty much an all day job to get it replaced. I also cut an access panel into the floor of that truck, and the pump stayed in tank. I believe the fuel also keeps the pump cooler.Putting a check valve on the inlet side of the pump may not be a good idea, pumps aren't that good at pulling, they are good at pushing. You may create a problem since the check valve will have some pressure it has to overcome to flow, even with a small delta.
The Walbro pumps with a check valve have it on the outlet of the pump.
You said what I have been thinking the whole time on this thread title.
I ran an external Frame mounted pump at first, but it was noisy and temperamental. Now I’m running an EP 381 in the tank like stock and it’s 1000 times better. I do dread changing it when it goes out though.me too.
https://ck5.com/forums/threads/fuel-pump-access-hatch.336684/Anyone know of an aftermarket access panel door made to convert the rear of a suburban deck so getting to the internal pump is easier?
