Ignition issues on a rather strange setup
I thought GM used the firing order to identify the cylinders..?
The #1 cylinder is the drivers side front most one,,followed by #3,#5,#7..
Passenger side front to rear, is #2,#4,#6,#8..
So,your 2 cylinders with low compression are #4 & #6 ..could be the head gasket is blown between the 2 cylinders and only "leaks" compression,(and no coolant) when it gets warmed up..?..
Its a Ford...
And that is clearly the problem :whistle: :waytogo:
Aha,I missed ONE important four letter word !..:doah:
Being a GM forum,I didn't stop to think this might not be a Chevy..:surepal:..or take into consideration my short attention span...
I DID read the first post..back when it was posted!..:screwy:..
