ignition switch removal
dheavychevy38
Algonquin,illinois
Ok guys I need to remove my iginition switch from the dash and swap it out cause when I bought the blazer it was missing the key :doah:. Any ideas I know on most of these you need the key and a small pin or pick to take them apart is there any other way? It's a 72 blazer
If you just need to remove the switch from the dash, you can unscrew the chrome "nut" looking thing that surrounds the lock.
Sweet thats all i need to do cause i have a new one. I just didn't want to make things worse by breaking things takeing them apart. Thanks Denny
There's a weird tool that you can use to do it or just take a couple screwdrivers and get it turning with the two or three small notches in the front. It's not difficult.
