Stumpuller
Registered Member
hey guys and gals...
gots another problem that i need some help with. I have an 82 s-10 that has a small block in it as one of my side projects. this truck is an on going project that will probably never be done but at least i can drive it now (hey thats the best kind
when i put it together i used factory gm HEI ignition. one wire to the distributor and its done. well im putting a 305 in it while im rebuilding the engine (hey its from a k5 so its cool). while its down i bought a real tail shaft cross member for the tranny. now the distributor hits the fire wall because it dropped the tailshaft. i have one of the ol points style of distributor on ye olde parts shelf with a coil, but im clueless as to how to wire it up. i think it will clear the firewall just fine.
any help so i dont burn my little truck up.
) when i put it together i used factory gm HEI ignition. one wire to the distributor and its done. well im putting a 305 in it while im rebuilding the engine (hey its from a k5 so its cool). while its down i bought a real tail shaft cross member for the tranny. now the distributor hits the fire wall because it dropped the tailshaft. i have one of the ol points style of distributor on ye olde parts shelf with a coil, but im clueless as to how to wire it up. i think it will clear the firewall just fine.
