Factory Hydroboost setup in my 88 Crew Cab V30. Lifted the truck this weekend and changed the box out to the 2WD unit for a cross over steering set up. Got everything together, ran the truck, no bubbles or anything, steered fine in the garage and the truck and had good brakes.
Took it out for a shake down run around the section and I lost both power steering & power brakes. I took it back in and went through the bleeding procedure that was posted earlier in this thread and still nothing... I did get some bubbles out while doing this but I still don't have any power brakes/steering.
It's entirely possible I smoked the pump somehow but it was working fine up until about 5-10 minutes into the drive... any thoughts??? Could I have just some massive air bubble that needs worked out still???
