I'm buying a D60 today - what do I look for?
Paxx
All Over Western Canada
I\'m buying a D60 today - what do I look for?
Ok I'm going to check out a D60 I found on a local board today. Its a 1986, is this a good year? I know that there were some years better than others.
So other than pulling the cover and checking the gears for missing or chipped teeth what else should I check it for? Thnx guys
~Max
Re: I\'m buying a D60 today - what do I look for?
if it is a dodge axle, it will have external hubs. see if you can get the spring plates with it.
[ QUOTE ]
[/ QUOTE ]
Depending on what year it is has a factor in that. The 90-93 Dodge version's have internal hubs like the GM 60's have.
What about the miltary CUCV type axles...are these neck up style or does it also vary by the year??
Actually either 79 or 80 were the last years for the neck down axles.
Plan to replace the king pin springs and bushings if they have never been done. If 4wd was not used much there might be a little surface rust in the pumpkin but it's nothing to worry about.
I forgot to mention that it is a GM D60 /forums/images/graemlins/thumb.gif
Spring plates... don't forget the spring plates!
Oh and what is the best way to check the hubs? lock em in and try to turn the pinion yoke?
sorry for the newb questions
Just thought I'd ask and since you (Wayne) a replying to this you would know best cause the D60/14B I have came from "TheGeneral's" truck and he got them from you. I for sure have to do the kingpins...she shakes like a MOFO and one of the seals is leaking out the driver side. That all gets done when I do the detroit in November /forums/images/graemlins/peace.gif
what about spring plates? I know that the only thing he says is wrong with the axle is the driver side spring pad has been cut off. /forums/images/graemlins/dunno.gif Didn't think that was anything major though.
Don't worry about the driver's side, that's the easy one to get (you could even use a rear spring plate from a 14 ff equipped truck to replace that).
It's the passenger side on that takes the bolts/studs that you need.
how much are they asking for it? I have one from an 85 with locking hubs- 4.11 ratio for 850.00 it is a SRW type and not the dually type
He wants $1100can for it which at todays rate comes to $841.31us dollars /forums/images/graemlins/grin.gif
I was talking about the u-bolt plates that go on top of the springs. They're different from 1/2 & 3/4 ton and can be expensive to buy. /forums/images/graemlins/thumb.gif
ahh I see, good point I wouldn't have thought of that. /forums/images/graemlins/waytogo.gif Thanks
As far as checking the hubs can someone give me a clue on the best way to do this?
You can make spring plates easy enough right????
Theres always somebody on ebay selling them for 30.00
dont worry about spring plates, you can always have peeps here on ck5 make em for ya. IMO, definitely not a "deal breaker" on a good used D60...
j
