blowedupmotor87
Okay, these may be dumb questions, I'll admit but, I am getting myself very confused.
Here's the deal:
I have an 87 GMC Jimmy with SM465/208 (32 spline long output shaft, long adapter). I also have an O.R.D. short 32 spline output shaft and short adapter waiting to go in it. So, in order to run that shorter output, I would have to get the tranny fully taken apart (might as well rebuild it anyway). But, in order to save time, I'd probably rather go ahead and buy a different SM465 and have it rebuilt with the output shaft, that way, everything can be done at once in terms of tearing the Jimmy apart. So, that's where I get confused!
1. Is the case the same on the long and short adapter 465's?
2. Can a long adapter tranny be drilled/tapped to accept a short adapter?
3. If I have to get a short adapter tranny, is it compatible with my hydro clutch stuff?
4. If I have to get an earlier tranny to have the correct bolt pattern to run the short adapter, what years do I need to be looking at?
2. Short adapter is called a "figure 8" right? That's what it looks like.
Sorry for all the questions, it's just confusing the snot outta me! Thanks!
Here's the deal:I have an 87 GMC Jimmy with SM465/208 (32 spline long output shaft, long adapter). I also have an O.R.D. short 32 spline output shaft and short adapter waiting to go in it. So, in order to run that shorter output, I would have to get the tranny fully taken apart (might as well rebuild it anyway). But, in order to save time, I'd probably rather go ahead and buy a different SM465 and have it rebuilt with the output shaft, that way, everything can be done at once in terms of tearing the Jimmy apart. So, that's where I get confused!
